IAC?????
uncltrvlnmatt
Pa.
I know a sticky IAC will cause a hanging idle. But will it also cause a a miss when the engine is cold. The miss only happens after the car has been sitting for long periods, more than a week. After it warms up the car runs great.
greenscobie86
The Big Apple
Mine does this too in a way...
I actually just cleaned my IAC this weekend(it wasn't too dirty) and that seems to have helped.
It also sometimes does it if I beat on the car really hard for a long period of time. then it will misfire for like 30 seconds.
I'm starting to think the plugs are original in my car so I can only guess weather or not the IAC cleaning worked or not until I pull the plugs.
MustangMoser
are you sure its a miss? the only thing the IAC is doing is letting air past the throttle body. it would have nothing to do w/ a miss fire. with it only happening after its set it may be an injector leaking down, washing out the cylinder. it would clear up after a little while of running.
TxCobrA98
i dont believe you are supposed to clean your IAC valves... just something ive heard.
anyways.. ive cleaned mine like 10 times, hopefully it helps! lol
U
uncltrvlnmatt
Pa.
I will try and clean my IAC this weekend. If that does not fix the miss after sitting, I will get the injectors pop tested.
Shifty Powers
Where the wild goose grows
Why not just replace it? I had to shortly after i got my cobra....
Was at the 1320 on the coldest night of the year and it kept bogging down while idling.. next thing i know it just died.. Would turn over but not start. Took forever to figure out it was the IAC Valve but it was such a relief when we figured it out..
