Idle control valve going.
Orange Stang
what are the symptoms of my Idle control going.
My car is running weird in this cold weather. Idles one area good, then surges either upwards or down, but it dosent stall out.
let me know.
joekd
Ct
Wow, waited a whole hour before bumping huh :)
Could be the IAC, pull it off and clean it with TB cleaner then reinstall. That alone may do it. Also check that the vac line is fine while you are there.
Also have you been using your defog setting on the heater lately? If so that can cause the AC to cycle on and off creating a surge off idle.
Orange Stang
Orange Stang
ha, yea, i wanted to know whats happening to my stang. I guess im either gonna get a new one from NAPA, or try to clean it, but the ford garage said it was really nasty when we first took it in when I got it. They said They cleaned it the best they could, and it would need replaced down the road, so I guess that means now, huh.
Thanks man, Im gonna try the T/b cleaner first.
Cody
Orange Stang
Orange Stang
also, the IAC is the part infront of the upper plenum, correct?
Im a noob at this. Never had to do it.
duff daddy
One thign you do not want to do in repairing a vehicle is DIAGNOSE to a part. Meaning you dont say this part has these symptoms so it must be that. You look at your symptoms, and go from there you dont just say well this part sounds lke it could be this so lets try that. Diagnose, then repair
Orange Stang
Orange Stang
well accually the ford garage told me it was going to need replaced come winter if it started to idle bad. It was fine this summer cuz they cleaned it the best they could.
Orange Stang
Orange Stang
yep, when I first got it it was idling funny, so we took it to the local ford garage, and they cleaned it and said it was running fine, but when It gets colder, if it does the same thing its gonna need replaced to come back in. So im just gonna do it myself and save some cash.
Thanks guys!
:headbang:
joekd
Ct
Yes, this is the piece on the front of the upper plenum that has a hose leading to your intake pipe, two bolts and one wire harness, simple swap
Orange Stang
Orange Stang
any tips on how to try to clean this and my MAF? just spray the T/B cleaner in it?
joekd
Ct
Yes, just remove and spray the IAC completely with carb cleaner. As for the MAF I used a special MAF cleaner they had on the shelf of my local Carquest.
vermilion
maryland
use a q-tip and clean again. keep cleaning til no carbon deposits but make sure flapper/plunger isnt deteriorated or sticking.
Staff online
