Idle Surge...Again
NJcobra94
NJ
so i posted awhile back to get some ideas on fixing my 94 5.0 idle surge.. Its has b303 cam, gt40x heads, 24lb injectors, replaced iac, cleaned the MAF, but it still surges... However it only does it when you first start it, whether its at operating temp or cold. It could be when i first start it up in the morning or when i start it after taking a long ride... It will hanging around 1200 rpms then drop and rise until i put it in 1st and move or feather the gas. Then it disappers and idles fine for the rest of the ride or until i shut it off and start it back up.
N
NJcobra94
NJ
ist has been calibrated for a bigger maf, i have monitered the air/fuel ratio to make sure its not to lean/rich.. but as far as tuning the computer has never been reprogammed or flashed...
N
NJcobra94
NJ
I've definitly gonna test for vaccums leaks soon, but with how the surge isnt constant and comes and goes im postive its not a computer issue even though sn's are notorious for their strubborn computers... ill post and let you guys know if i find its a vaccum leak.
N
NJcobra94
NJ
checking back in on this post.. a buddy of mine told me to take the iac back off and dissonnect the battery to reset the ecm.. Then put the iac back on and run it for an hour or two.. so i did that and pretty much ironed out all my problems.
