If your cammed get in here
Dalamar
SLC, UT
There wasn't a reliable adjustable cam gear when I did mine. you'd hate to have it slip and blow up your motor.
I did have mine degree'd, which is a good suggestion.
you'll have to call powerheads about the cams, they're not listed separately on their site.
http://powerheads.com/powerheads1.html
duff daddy
The Comp 270's have a very noticable idle, you can definatly make it more noticable then my car for where you leave the idle. I had mine set at 900, and ive heard when people leave it around 700. Personally I dont care how the car sounds when it idles, as long as it runs good, makes healthy hp (not to the edge) and runs consistant. Its when you tell your tuner "make this thing sound like an animal when idling" that your going to sacrifice reliability.
As far as adjustable cam gears, Nick @ Modular Head Shop sells them and they workwell, how ever I will be degreeing my cams and using STOCK gears, and just grinding the keyway.
Listen around :50
96 gt pi swap idle
L
lanthony155
that sounds sick. I think thats exactly how i want mine to sound. And for the cam gears, i can use my stock ones? cuz im not trying the drop $240+ on new cam gears. Also did you change your springs i know it recomends it but i hear some people dont do it.
duff daddy
I had ported heads then ith teh 270's so id suggest new springs, can you get away with it, im sure you could. and for the gears ....im spinning my new motor to 8,000 and im using oe gears with ground keyways.....
atlanticblue98
i really really cant wait to hear it. you keeping the magnaflow's and H-pipe?
duff daddy
BBK Long tubes BBK off road H pipe (short) Magnaflow with no tail pipes, (down before and out the tires)
atlanticblue98
although i am an X-pipe fan, it will sound absolutely amazing
duff daddy
x pipes are too ls/4v noise....... H pipes are more muscle and more "meat" sound...although the LT's will change it all and who knows what this thing will sound 4/5's of the way to 10k!!!!
1996mustangGT
Talk to Nick over at MHS and get a recomindation from him, he'll set you up.
Also, you really dont need to spend $300 on adjustable cam gears...just grind the keyways like Duff said. My builder did that for my 5.4 and its been running like a champ. If you really want to though, get nice ones, and make sure to loc-tite the **** out of them.
duff daddy
If i didnt trust nick i wouldnt let him do my cams/head work and i def wouldnt be running his name on my quarter panels
jwyche
I've been very happy with my Stage 2.5 N/A cams from Cushman Motorsports. Jim Cushman, who will actually discuss your needs at length, is the designer of the famous VT cams. These puppies do love nitrous. Ground by Bullitt they come in at .571"/.567" lift, 230/237 .050 duration, 109 LSA. They may not be for everyone as they come on strong (at least in my case) about 3500 and run hard right out the back door. I'm sure there are a number of really good cams out there and this is one of them. I'll try to include video but I'm not sure this will work so I'll give a link, too.
Jim
http://s273.photobucket.com/albums/jj240/jwyche_photos/?action=view&current=2002GTRunningcopy.flv
http://<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http://vid273.photobucket.com/albums/jj240/jwyche_photos/2002GTRunningcopy.flv">
duff daddy
Lee12609 said:
i hate CAM threads in the modular forums.
:) I was going to say something but its like arguing with people when they put rims and they are talking about a wheel.
98GTnSC
well what help the guy(and the rest of us reading) with our camS situation... lol
Lee12609
stock bottom end = MHS
or notched piston bottom = MHS/COMP/HITECH/CMS/VT's
pick one, call/PM/email the manufacturer your combo and expectations and let them make a suggestion....
i absolutely HATE people that decide on a cam based on sound or someone elses experience with it. modulars are very finicky with cam selection. most N/A modular cams worth mentioning really need notched pistons.
