ignition coil mounting screws glow blue
heehaw80
opened the hood in the dark to check something, engine was running and before I turned on my shop light I seen that two of the four mounting screws were glowing blue!!!! Also that everywhere that all eight plug wires touched metal where arking!!!! I know I need plug wires but would that cause those screws to glow????
MustangChris
Aurora, CO
woooooooooow. replace your wires NOW. if they are arching through the insulation, they've been neglected for some time.
H
heehaw80
X act advance auto brand they were put on the engine two years ago right before I got the car the receipt was in the clove box says that there life time warrentied
the5.ohh
Shaolin, NY
get those off asap.. get a set of ford racing 9mm wires and be done with it. I have longtubes and I have no issues with my wires, and longtubes make everything a lot hotter than stock manifolds.
H
heehaw80
I have a ground wire going right to one of the starter bolts, put that on a week ago with the new rt o2 sensor
sanded the paint/connection on both ends prior to installing it? I would double check it and your other grounds.
rz5.0
Great state of TEXAS
Cheap under hood glow. . If wires are arking replace them. I have some pretty much new. Also a coil..
I think your coil is grounding off the bracket. Check all your grounds. Specially battery to block..
I had the same thing typed out in my last post before I deleted it. Shouldn't it ground to the chassis just like anything else does?
shorty
awww pics would have made this post even wayyyyyyyyyy better
Paul
The glowing is probably residual radiation from the Fukishima meltdown if I had to guess.
H
heehaw80
replaced the wires with 9mm wires and no more arking and no more glowing screws must of bin from the spark jumping to ground and the coil already being grounded
Jerry santos
