Im not much for bench racing.... but.
95Grandtouring5.0
Im going to run the stang at the track tonight for the hell of it to see what it will run. I'm Looking for a few time guestimations.
95 GT mustang.. Hard top
4:10 gears
pro5.0 short throw shifter
ford racing aluminum drive shaft
bbk cai
bbk 70mm tb
ford racing king cobra clutch kit
taylor wires with msd cap
Spec aluminum flywheel
ford racing water pump ( as if that has anything to do with it)
bbk underdrive pullies
And that's all I can really think of at the moment.
Venom351R
Maine
4:10 gears
bbk cai
bbk 70mm tb
The 4:10 gears will help but not to much on there that will really lower your 1/4 times. Depending on your driving ability and traction with the type of tires your running Id guess anywhere from high 14's to mid 15's
Spd0lit
SoCal
You are going to see anywhere from low 15s to mid to low 14s. With the mods in my sig i ran a 14.32 with a 2.2 sixty which can be improved with a better tire. Your mods are pretty similar to mine so i think you should be down in that area.
95Grandtouring5.0
I forgot to add that I have a mac cat-back and bbk catted h pipe. It was too bad it got rained out tonight... perhaps friday.
foss_94gt
are you auto or manual? if 5 speed with those gears you should be able to hit a 14 easy
Paul
Ive run plenty of cars. You ran a 13.9 paul? Was it hooking up well?
Yep, 13.98-13.99
The car wasn't really hooking up, as my 60' times were only 1.995 - 2.001, but my car just seems to run okay for how slow the MPH is. I never though it would run that quick. I'm in the right lane on the first slip and the left lane on the second - they mixed up the car numbers a bit.
I have nittos, 3.73s, shorties, catted x-pipe, flowmasters, intake/tb, and a shifter. No pulleys, no weight reduction of any kind, and 100% original suspension.
Paul.
Downshift
Yep, 13.98-13.99
Paul.
Damn Paul, Nice times. What was the temp and elevation thats at?
Paul
I'm in Phoenix, so maybe 14-1500 ft? Air temps were pretty decent I think - maybe in the mid-70s that day? I can't remember. It wasn't hot though.
95Grandtouring5.0
Well I ran, didn't do so hot. Car spun real bad and just would not hook up. My best run was a 14.8 at 95mph. 2.2 60 ft
One run I missed third gear and still ran a 15.3, if I didn't miss third I think I would of ran a mid 14.
96GTPlanB
