Info needed on egr delete -
FrankenStang
bum****egypt
hello, im the process of doing my Pi head swap and i destroyed my egr tube to get it out and now cant get the old one off the old headers....so i capped,crinked and hammered the end bit of the egr tube so it would be air tight and i will make a blockoff plater for the plenum....
What im wondering is is the sensor pictured below sapose to be fully removed, its the one with the 2 lins that run into the egr tube...or do i leave it plugged in and worry about it once i get my custom tune...also will i have any drivability issues with it deleted and no tune?
clark98gt
Pennsylvania
I just capped the port on that sensor that went to the egr. I havent tried to eliminate that, if you do post up wether it works or not.
FrankenStang
FrankenStang
bum****egypt
capped the port on the sensor?? you mean where the tubes come off of it?? did you block off ur egr or disconnect it from ur plenum?
clark98gt
Pennsylvania
I capped the egr tube port on my exhaust manifold, made a plate to cover where the egr used to go on the intake elbow, and put a vacuum cap over the port on the sensor where the egr vacuum line used to attach.
