Info on heads
95mattstar08
Rockingham nc
Need info this is my first sn95 and I need to find out if the heads are cast or aluminum from factory I bent 8 pushrods when it over reved cause 2nd gear went out on my t5 trans
white95
Apex Junky
Admin
Prairieville, LA
If you can stick a magnet to them, you have iron heads. Send in some pictures and we’ll figure out if they’re stock or not
I can get my crystal ball and tarot cards. For a small charge I can tell you if they are aluminum as well as what you need to do to find the woman in your dreams at the same time. 2 for 1 special just this week in fact but only for another 48 hours. Being psychic I already know you want to give me your credit cards so just pm me.
beyondEOD
Car tuned at all or cammed? Should have hit the limiter at 6250.
Sent from my SM-G960U using Tapatalk
95mattstar08
95mattstar08
Rockingham nc
Lmao no I have the woman of my dreams and we just had a 13 year anniversary so naw I'm good
evilcw311
Most Evil Member!
Louisville, KY
They are aluminum heads that's why I was asking about them
Uuuhhhh.......the first thing you posted you were trying to figure out if the were iron or aluminum. Did we miss the post where you came back and told us what the heads are???
Factory heads are iron and your post made it sound like they are factory
95mattstar08
95mattstar08
Rockingham nc
If the motor is stock they’re cast iron heads. Give us pics and info.
I don't think it's stock the guy I traded with said I had a small cam in it and that's about all I know about it I do know that it revs real quick but it does have stock rocker arms on it
evilcw311
Most Evil Member!
Louisville, KY
Post pics of the motor and try to get pics of the heads. You can post straight to the forum from your phone or you can use the app Tapatalk.
95mattstar08
95mattstar08
Rockingham nc
95mattstar08
95mattstar08
Rockingham nc
This is my first mustang that I've ever owned
beyondEOD
Ok I think there could be a few issues. I can't tell what heads those are the pictures are not showing on my phone but we know they are aftermarket if their aluminum.
My concerns or possibilites:
1. Valve springs are not heavy enough for the camshaft.
2. Piston to valve clearance is way to tight.
3. Stock rev limiter was raised in the tune.
Things you can do depending on how you want to tackle it.
1. Remove the timing cover, timing set and see if the cam is labeled. ID the cam. Remove a spring and have a machine shop measure the spring rate. If the springs are not adequate replace them. Check limiter in tune.
2. Swap the cam and springs entirely. Check limiter in tune.
3. Check limiter in tune. If it's set way higher than factory. Reconfigure and replace the pushrods.
Hopefully a valve is not damaged all together.
95mattstar08
95mattstar08
Rockingham nc
It all started when I went to store the other day not even an 1/8 of a mile away ooh yes and it doesn't have 2nd gear and I did rev it a little hard and it clanked and cut off had a hard time getting it started back and if I let off gas coming back home it cut off. But it would idle fine but there was a slite tap in top end of engine
