Injector size
snakesonastang
Hey guys, I"m starting the supercharger install next month on my 342 combo. I'm going to be running 6 lbs of boost d/t compression and was curious on what size injectors. My rear wheel horsepower is 310. I've calculated my horsepower should be around 500-540 at the crank with 6lbs of boost. Also I have a higher than normal compression ratio of 10.5-1. Would 42lb injectors be enough or should I go with a 50lb injector. Thanks for your help.
97stanger
Ive heard that 42# should be good up to 500ish. better to be safe than sorry though and get a little bigger injector in case you decide to grow down the road
LAFENATU
50Fanatic92 said:
14 Lb/Hr 228 28.56 Gray
19 Lb/Hr 310 38.76 Orange
24 Lb/Hr 391 48.96 Lt Blue
30 Lb/Hr 490 61.19 Red
36 Lb/Hr 587 73.44 Dk Blue
42 Lb/Hr 685 85.68 Lt Green
60 Lb/Hr 800 100
These are all N/A numbers. Boost is a completely different animal with injector size/rating.
realitygt
60 Lb/Hr 800 100
it's also different for what rpm u shift at. my friend maxed out his 19lber's on his probe at 190whp cause he revs it out to 8100rpms lol
Venom351R
Maine
#42's are quite common when it comes to H/C/I ( typical no wild combo set ups) and boost of up to 10LBS. You can run injectors at 90% duty cycle until the fuel requirements start to become to much for them. It wont hurt to go higher then #42's but I wouldnt consider anything lower.
Jrgunn5150
I ran 42's with my 10.3:1 C/R 10 PSI 2v and was at 78% duty cycle at WOT, they are plenty.
