snakesonastang
- Joined
- Nov 15, 2007
- Messages
- 84
- Reaction score
- 0
Hey guys, I"m starting the supercharger install next month on my 342 combo. I'm going to be running 6 lbs of boost d/t compression and was curious on what size injectors. My rear wheel horsepower is 310. I've calculated my horsepower should be around 500-540 at the crank with 6lbs of boost. Also I have a higher than normal compression ratio of 10.5-1. Would 42lb injectors be enough or should I go with a 50lb injector. Thanks for your help.
