Inspection with out smop pump ?
94greenhunter
Can i pass the texas state inspection with no smog pump and high flow cats? please help i need to get my car inspected.
Jrgunn5150
I have no idea man, depends on your car. I'm assuming you live in a county that does emissions testing, in which case I would wonder why you removed your emissions equipment first, then wondered if it would pass.
94greenhunter
well i removed it because i put 2 new pumps on there and 2 locked up on me and one the pully came off and was not able to find the pully
Downshift
Just thought I would say that I took my car to a muffler shop to get new flanges welded onto my stock H pipe for a quick smog lol. Well the left the smog pump tube completely off and the mid pipe uncapped and I passed with below average on every category tested. And that was in Smog Nazi California at a test only station. Oh and when I pulled my headers off afterward I found out that the bung for the EGR valve was a fake. :laughing5:
eliyarbrough
Nocona, TX
I live in North Central Texas.  My inspector put on my smog delete, even recommended he remove all of my cats!  I'm not sure where you are though.  My guy here will inspect it!!!
That's out!! You are way too far away from me! I tried though.
94greenhunter
i am in Houston. i found a guy that will inspect it but it is going to cost me $125 to do it. but i think that i just might take it off the project car and put it on mine just to get the sticker.
StAnGaLaNg
just go to a maw and paw muffler/tune up shop...they dont give a rats @ss. thats what i do, they just charge a few extra dollars...it ran me $20
stang94X
i have no smog pump and had high test gas in when i went to e-check last september and past better than when it was stock, all you have to do is drop the timing down really low, it reduces the temp inside the motor and doesnt produce as much NOx, the cats alone with get everything else passed
or don't f... with the timing and just pull the spout. it'll run like dodo, won't rev as high. that's what i had to do last year.
when you change the timing you have to pull the spout connector. it's a gray plug located near the air filter (maybe under or behind it). it keeps the computer from advancing the timing
stang94X
i tried doing that at first, it was reving to all hell and i was only going like 25, i couldnt even make down the road
stang94X
when i said reving to all hell, i meant for how fast i was going, it wasnt like 4000-5000 rpms or anything, but when the gas pedal was more than half way down and im only going 25 mph and the rpms are like 3000-3500, i didnt want to drive it like that
