03DSGGT
SN95 Supporting Member
Hey guys, I installed my coilovers the other day on the Mustang. I installed AJE tubular A arms and Strange coilovers with 12"/170# springs. I'm running Tokico Illumina 5 way drag struts. I installed everything correctly and added MM bump stops and bearings that sit on top of the spring for easier adjustment. I have 2 larger spacers (I think theyre 1/2") under the CC plates (MM) and one smaller spacer on top under the nut. Everything seems to be how it should, but I really have no adjustment with the ride height. I started off with the spring seats about halfway up the sleeve. This gave me about 3 fingers between the top of the tire and the fender. I adjusted the seats all of the way down as far as they can go and I can now fit 2 fingers in between the tire and fender. I would think that I could slam the front end more especially with 12" springs. When driving down the road, the front end is silent and takes normal bumps pretty well...its a little more bouncy but from what Ive read, that's somewhat expected with coilovers. The issue is when I hit a "hard" bump, like the uneven step going over a bridge or a pothole. When the car hits them, it sounds and feels like the front tires are solid rubber, and I would swear its bending the rims by the sound. It makes driving the car really tense and I'm not sure if this is typical or not. I'm not sure if this and the lack of adjustability is related but if so and this is typical of coilovers, I may go back to coil springs.
Here is a picture of the front end adjusted all the way down. Seems like it should be lower:
