I did this swap not that long ago. I did them on jack stands and could NOT get the car high enough off the ground to get the drivers side header in. I could not get the right angle, it kept hitting the ground, maybe if you got some for trucks you could get the car high enough, but I would just unbolt the steering shaft it is not that hard and took maybe 5 minutes to get it off (you have to spread the ears on it a little to pull it off the rack) I didn't unbolt the starter on the pass. side but it was hard to get the header down past the starter, If I ever do it again I would just unbolt the starter.
