94Pro-5.0
so i'm having a lot of clearance issues.
First issue: my GT40 tubular intake has 2 fittings that are on the bottom/ drivers side of the intake. These fittings hit my valve cover. I removed the fittings and want to know if the holes can be plugged. i dont know what supposed to go to these fittings; vaccuum or something?
Second issue: I have a TFS Elbow, BBK TB and 1" spacer to go between the elbow and intake. My TB hits the valve cover. I was told if i had the 1" phenolic spacer and 1" TB spacer that my tall valve cover clearance problem would be fixed, but it still need to be about 1/4- 1/2 inch higher.
So, do i just need to stick another 1/2" spacer on top of my 1" phenolic spacer? The reaon i dont want to do this is it makes my intake hit my hood. so i dont know what to do.
what do you guys recomend? Fox intake swap?
