kissrocksforever
Okay so you may have seen a few of my other posts about oil leaks/pressure. Well I just found out something else.
I was discussing with a friend earlier, and I told him about a whining/whistling noise coming from the engine, that goes up and down as the engine revs. He said it could be a bearing going bad. There is no knocking or anything and everything else sounds normal.
This got me a little worried, but then I found out when a bearing goes the oil pressure goes down, Now I realize the stock gauges arn't so great but this is the first time ive seen a drop in oil pressure on the gauge (from right in the middle to between the O and R of normal...sometimes on the R.)
again, I know many of you have said the oil gauge is nothing to worry about, and when I originally posted about the whining noise people said that if the engine was running normal it was nothing to worry about...But now both things at the same time have me genuinely concerned.
Based on what I've said here, I want opinions. What could it be? and what's the worse case scenario, and what would it cost to fix?
help lol.
~Andrew
help lol.
~Andrew
