is Rhinoliner/bedliner heat resistant?
I am going to drop off my shinoda chin and S281 decklid spoiler this afternoon to get painted. I know that no matter how hard I try that there will probably come a day when I scrape the chin no matter how carefull I am. Because of this I am going to cover the bottom of it with a bedliner material that will hopefully add another layer to help hold together when it does happen but also to just make for easy touch-ups afterwards. Going too do the bottom and maybe around the bottom edge leading towards the front so a slight line of it might be visable. While I do that I am also going to do the bottom of my side exhaust skirts for the same reason and was wondering if I need to stop before I get too the end where the tip is too keep it from melting later or if it would be ok to go all the way down the bottom?
Orange 94
Alberta Canada
i think its suppose to be fairly good against heat, but I wouldn't expect it to last on the actual exhaust itself?
Not sure! I'm sure some 4x4 guy has just sprayed everything before.
