It seems like I'm always asking q's
BruhBrahBrad
Ok, 2 new questions, My car squeals like no other on start up , the noise seems to be coming from the belt/distributor area. What is it!!! It is so annoying.
Also Has anyone put in a quarter window. If so how do you do so.
EastBayStang98
im sorry i cant answer ur noise question, as for the glass ibelive theres are screws just holding it, theres also adhesive
EastBayStang98
yes sir. the reason i know is cus i saw a guy from a junkyard in san leandro take one apart. which window do u need? do u have it already?
B
BruhBrahBrad
Yeah I already got it, And I got the sealant that comes in a tube i just need the nuts that secure it
B
BruhBrahBrad
I think I'll go to the hardware store lol, its just that......I dont have my license lol
could also be the dizzy itself. next time you start it, while it's still squeeling push back and forth on the dizzy cap. if the noise changes there's you prob. that's what mine is doing now. it's also a common prob with the 5.0's with some miles on them
the tensioner pully is what keeps spring tension on the serpentine belt so you don't have to manually tighten the belt. cost IDK you should be able to call the parts place to find out. not too much $
94 DropTop
if you say its coming from your dist area it might just be your idler pulley, or it could be your belt tensioner, or hell it could be the belt itself. Pulley-15-20, tensioner-40-60, belt 20
topless95
Try spraying a good quality lubricant onto the backside of the idler pulley and see if that takes care of it. If not use some soap on the belt while its running, but be careful. Let us know what you try and the results
