i pulled the center console out of the car over the weekend, and when i got around to putting it back in, the cig lighters and my speedo (controlled by speedcal wired into power feed for 12v power source) dont work. as far as i know, i have everything connected back together correctly, since i cant put anything in the wrong spot.
my next step would be to trace the wire loom back to its source, but i cant imagine anything beyond the console is wired wrong, since i didnt touch anything that wasnt under the console.
also, i have two square female connectors coming from the power feed off that wire loom. one (casing is either white or a shade of gray) goes to the fog light switch, and the other is a brown one, which does not fit the fog light switch due to a different notch in the casing. is this one for the vert switch (which would be just dangling, unused for coupes?)?
im about to go fuss around with it on my lunch break, but i dont know how far ill get with it. i could care less about the 12V power, but since my speedo is wired into it, i kinda need it fixed asap, since im judging my speed solely on other drivers and my tach.
