Just my LUCK!
96dkgreengt
i had the same thing happen to me. i was driving all fine then i couldnt put the car in gear at all and clutch would go to the floor easily. come to find out the tob was broke into 3 pieces. i could be wrong but i hear if its a aftermarket tob some are crap. always use ford oem tob when you change your clutch.
CanaryGT
Phoenix
+1. I already have my ford part waiting to go in.
johns94gt
Roanoke, Virginia, United States
Javi said:
Mikes347 said:
My throw out bearing more than likely exploded.
Not to thread jack, but i just changed my TO bearing,clutch,pilot bearing and the cable, everything was torqued to spec and my cable and quadrant was recently changed before i got car. Well my TO bearing is making a chirping noise but NOT even close to that loud do you think i need to replace it again?
sn95jones
Arlington, Tx
Hmm odd I have the same kinda squeeling sound going on in my car, but I think it may be the belt but I could be wrong.
98Viperblue
If you have that squealing you will feel it on your clutch petal.
Today I placed a big order guys!
Ordered
-Spec Stage 2+ clutch kit
-Maximum motorsports clutch cable
-aluminum double hook quadrant
-firewall adjuster
-2 Tokico HP rear shocks (my right rear has been thumping)
-steeda bumpsteer kit
-Maximum motorsports CC-plates
Also I sold my hood for 400 to a local, and now I just ordered a saleen heat induction hood from ABCexclusive
Needless to say the car should be back up soon, and it will be slammed.
BruhBrahBrad
Would a Bad TOB give you problems going into second? Cause mine is chirping and has been since I put it in.
sn95jones
Arlington, Tx
The way to tell you have a bad clutch is, if its making a sound without the clutch pushed in, and if you push the clutch in the sound goes away then its your TOB
Mustang Mark
johns94gt said:
i have the chirping noise but do not feel anything in the pedal and everything is brand new so i dont kno why it would be bad!!!!
you cable may just need to be adjusted.
Win
Kennesaw, Ga
Mikes347 said:
Getting into one particular gear could be a fork or a syncro I think.
If your having trouble getting a gear it can be the shift fork or gear selector as some refer to it as. Usually if a synchro is going out or gone you can still find the right rpm's to slide it in with minimal grinding if you know what your doing.
