Win
Could be your Clutch disc that decided to come apart. When you say Metal Get us a pic.
96dkgreengt said:i had the same thing happen to me. i was driving all fine then i couldnt put the car in gear at all and clutch would go to the floor easily. come to find out the tob was broke into 3 pieces. i could be wrong but i hear if its a aftermarket tob some are crap. always use ford oem tob when you change your clutch.
Javi said:Mikes347 said:My throw out bearing more than likely exploded.
Not to thread jack, but i just changed my TO bearing,clutch,pilot bearing and the cable, everything was torqued to spec and my cable and quadrant was recently changed before i got car. Well my TO bearing is making a chirping noise but NOT even close to that loud do you think i need to replace it again?
you cable may just need to be adjusted.johns94gt said:i have the chirping noise but do not feel anything in the pedal and everything is brand new so i dont kno why it would be bad!!!!
Mikes347 said:Getting into one particular gear could be a fork or a syncro I think.
