Thanks for all the comments guys, and like I said, I just picked it so havnt gotten around to do much to it yet, moneys a little tight now haha and as everyone here knows, making it yours takes time and money. But the wheels are different, I like em. And they arnt gold, just dirty haha, gotta polish em up. The hoods not the best quality aftermarket, so it isnt lining up quite right, might pick up a new one and loose the hood pins, especially since they're not functional. Ill get some better picks up soon when I get a chance but heres the mod list for it just incase you dont like the hood pins:
ccasion14:
Engine:
Eagle 331 stroker bottom end
TFS Twisted Wedge 170 heads
TFS Stage 2 Track Max, hydraulic roller tappet, Duration 292/290, Lift .542/.563
TFS stud mount, full roller, aluminum, 1.6 Ratio rock arms
TFS chromemoly pushrods
TFS Track Heat intake
TFS timing chain and gear set, true roller, double roller, billet steel sprockets
ARP head bolts
28 oz. Pioneer Race Balancer
Moroso 7qt pan with -10 an fitting welded in for oil return (with fresh Mobi1 10w30)
MSD coil, distributor and wires
BBK 65mm throttle body
BBK cold air
Lightning 80mm MAF
Ford Motorsports 42lb injectors
Walbro 255lph fuel pump
New fuel filter
BBK fuel pressure regulator
NGK TR6 plugs
Smog pump delete
EGR delete
SCT 4 bank flip-chip
Wheels/Suspension:
TrueForged 3 piece Chicanes (18x9, 18x10.5, fully polished, 04Sleeper offset, Gorilla locking lugs, with Nitto NT05 tires, 295/35 rear and 245/40 front)
Ford Racing front lower control arms
Full length Kenny Brown sub-frames
H&R supersport springs and Tokico HP series stuts and shocks
Kenny Brown front strut tower brace and rear shock tower brace
Kenny Brown caster/camber plates
Drivetrain:
FMS 3:73 gear
New Spec Stage 1 (approx. 1000 miles on it)
Centerforce steel flywheel
New Maximum Motorsports quadrant
New firewall adjuster
B&M ripper shifter
Exhaust:
BBK longtubes
BBK o/r h-pipe
Flowmaster 40 series mufflers, dumped
Interior:
Black leather seats
White face Cobra gauges
Pioneer head unit with double din kit
Tinted windows
SVT embossed rear seat delete
Exterior:
New headlights and marker lights from Blue Oval Industries
Cobra R 2.5" style hood
Other:
Battery relocated to trunk
New TFI module
New IAC
New front hubs
New Fel-pro pan gasket
