Just spent 6 hours installing Shift Kit
Fets
Started at 9am, and got done around 3 pm. Not that hard of install, then again, I was just learning (Im 18 haha) and watching my Uncle and Dad do mostly all the work :ass3:. Shifts a little harder, but I was expecting more. Does it have to break in? Overall Im pretty satisfied. I can't wait for the 4.10s to be installed next week though, along with my new ratchet shifter 8)
Lightning Struck
what level did you set it on? If you did 2 or 3 it should be a pretty big change from the way it shifted before, barking 2nd EVERY time
F
Fets
Well the first time, we went with the last setting, which I guess would be 3. But we couldnt fit the valve and spring into the tranny because it was tooo stiff. Then we went with the 2nd level which is where its set at now. Im not complaining though, it does bark 2nd. Thanks for your guys help
Lightning Struck
OK so did you drill the holes for a 3 or 2? The hole size ( the bit you use ) determines what level of the shift-kit it is also. I set mine on 3, to the best of my memory.......and you could TELL big time, you could do gradual acceleration and the damn thing would chirp the tires I LOVED IT :pimp2:
RobertC
