K Member Install with Team Z
ivan12
I have their k-member, A arms, bump steer kit, strange coilovers, and Rear UCAs. They sell quality products, on one of their other videos they show you the difference between their stuff and another brand and how Z uses a small diameter tube that's beefier than the competition's bigger thinner tube. Plus their service was really good when I had questions
that's it? The way MM explains the install is WAY more in depth as far as aligning everything and making sure it's square to the rear of the car.
Paul
Tube K-members are a pretty simple job. I've installed a bunch of them.
Team Z makes good stuff. I have their entire mini-tub and rear suspension kit with the Strange coil-overs and whatnot. It all fit well, and went it reasonably easy. (relatively speaking)
Paul.
BlkoutGT
MO
Paul.
Says the guy who decided to put in hush mat, then decided to remove dash and put more down lol.
Another plus is there k members are tig welded.
det_riot
Dearborn
I will be going teamZ when i Get my tubular k and A arms! Gotta support the local business
Knuckles@Empire
Knuckles@Empire
-Never Forget-
In front of you
interesting I am a couple days away from ordering some m&m suspension stuff....
DONT DO EEEET!!!!
I kid i kid, lots of companies making quality products. I obviously am a bit biased towars Daves stuff but i wouldnt be unless i thought they were running the best. ill make sure to post any newer videos as they come up.
ivan12
Lots, team Z K-member is $289 MM is $649, standard Z arms $269 MM arms $349. Have to use coilovers with the Z stuff but you can get the kit (K-member, Arms, Coilover conversion kit) for $739 just add strange adjustable struts. You might save a couple of bucks through different vendors but the difference is still there
I feel like you get what you pay for. Team Z makes two different quality and priced K members, why not just make one that's good enough for everything?
SRT Handz
QTF. MM has always provided me with the best quality parts and AMAZING customer service.
