Kenne bell 1.5 to 2.2 swap
So if you do it
Makes you pay close attention to what you are removeing
Also pay close attention to part difference
Down to the shims
95opal
Its possible when swapping a 302 1.5 to a 2.2 kb as long as its for a 302 not sure about the differenve between the 4.6 vs 302 units.
JFI
The 2.2 impellers wont work in the 1.5 housing,unless you swap out the 1.5 bearing plates.The cost of this is quite large,and not worth the expense....,but you can just upgrade to the 2.2 compressor with your 1.5 manifolds,and all you'll have to do is tap one hole. Again not sure about the 4.6 units.
Unless your motor is built and you plan on running more than 9psi i dont see any benifit.
MasterDot
Washington state
JFI
Yeah I have a decently built engine, I was only going to swap the manifolds, I wasn't planning on touching any shims/rotors or anything purely manifold and snout only. I'm hoping to get 15 ish psi
95opal
After looking at the 4.6 version it doesnt look like the snout will align with the 302.
Bronco2Fan
Texas
I don't know if you've done this already, but have you thought about or tried to ask the folks at Kenny Bell for info. Since they're the manufacturer, they ought to know.
MasterDot
Washington state
Yeah I have I tried to get ahold of them but I didn't get through, Im calling tomorrow mostly because my work runs when they close
Mikehonco69
