Kinda thought this was interesting
BruhBrahBrad
sooo today i went to mess with the timing,and at stock 10 degrees. it lopes hella hard....but it doesnt drive, which leads me to believe the cam is actually larger than I thought, because I know 94-95 cpus are hella finicky with cams that are too big. I was told it had a aftermarket cam, but not what cam. Combined with the 24's that dont have a calibrated maf I think Im kinda needing a chip or a tune or somethin. It doesnt get up until about 2500 rpm's, but that could be because of the 2:73s....
What do you guys think?
B
BruhBrahBrad
Also the car always has difficulty starting, but once it does its good... could it be getting too much fuel?
HISSIN50
Running 24's without the EEC knowing they're not 19's can lead to issues alone.
Have you pulled codes?
Any vac leaks?
B
BruhBrahBrad
yeah i had got 179 and 188 basically rich codes... so im gonna probably get a set of 19s and run those till I actually need the 24's
I have 24's on an otherwise stock motor. Bumping my timing and running 93 octane didn't really change the driving of the car. Still runs mostly like poo haha.
2002BLGT
Bedford VA
if you put 24lbs injectors in you MUST tune the car with a chip for it , or get a calibrated MAF for the 24lbs injectors , otherwise you will have issues and probably wash the rings out of your engine in a short time
