Lightning motor swap into a 98GT?
N2Otorious
Ok guys and gals.
I have a 98GT, right now I have the 4.6, PI heads, Cam, and Intake, BBK 75mm TB, T-rex, Green top focus pump in tank, Vortech V1 with a S-trim, and a Front mount intercooler that hasn't been installed yet. My engine has 125K miles on it, I did a cylinder leak down test and 2 cylinders were at 16% to the crank case.
ok, shes old and worn, let me rebuild it... but wait...
Made a deal with a buddy today, he wants my whole engine complete(he is fully aware of it's condition), and he's trading me his 2002 F-150 Lightning engine COMPLETE!...
Has anyone put a 5.4 Blown engine into our SN95 cars? What must I not forget to pull out of his truck to complete the swap?
ryclef331
Its been done but I doubt you'll find ANYONE on here that has done it. Hood clearence is an issue though....
Jrgunn5150
There's a member who has done it. There's really nothing you need except the engine and all the accesories, your harness can be modifed to run it, and your ecu can be flashed.
Like Ryclef said though, there isn't a cowl in the world big enough to hide it, so I would just cut a big hole in the stock hood, since whatever hood you get will be cut anyway.
1996mustangGT
its the same as any other 5.4 swap just you have a blower on it instead :coolsmiley:
its been done in a fox-body so pretty sure you can do it in a sn95....you'll need a HUGE hood though...
N
N2Otorious
Thanks for the responses guys..
I knew the hood would be an issue, I have no problem cutting the stocker, I use to seeing a blower hang outta the hood, I ran a 8-71 in a 68 Stang years ago.
Anyone know of what or where I can read info relating to the wiring harness modification?
i think one of the guys at spyder turbo did it. at least i saw a pic of a lightning swapped sn95. pm him or email their website
N
N2Otorious
Spyder Turbo? Never heard of them...
GaryG
Jessica is on here, i believe her username is Toxic5.4, ill double check tho, i havent seen her on here in quite awhile
N
N2Otorious
That looks bad ass.
I cut the hole in the stocker... no need in ruining a cowl hood.
Jrgunn5150
The only mod's to the harness relate to the temp sender's. There's nother involved other than lengthening of some wires, nothing tricky or anything.
You would want to fab up a way to mount your coil packs also.
N
N2Otorious
Well hell, this sounds easy...
I can fab stuff..
I figured I'd have to make brackets and stuff for the heat exchanger, and the H.E. water pump mount.
Jrgunn5150
You would have to come up with a way to mount the HE as well, but I mean you seem inclined for this type of thing. It would all be obvious once you have it sitting on the mount's.
The main thing is to have a tuner lined up ahead of time, so you can at least get a baseline tune to run to the dyno with, or have a trailer ready to tow it.
And buy some stock in a tire copmany :2funny:
96GTPlanB
