Lights aligned?
eliyarbrough
Nocona, TX
Can y'all give my an example of where I could go to have all of my lights aligned? For sure my driver's HL is a touch too high! I just have no idea on who could do this. Thanks!!
Steven
SC
if you have a garage door (which i surely hope you do lol) pull the car up while its dusk time and get it close to the door.. a couple feet is all you need room wise. Pop the hood, turn on your lights inside, and use the lines on your garage door's as tick marks to adjust.. thats how i do all of mine :dunno:
eliyarbrough
eliyarbrough
Nocona, TX
I thought to myself how to get them on line. I take a tape measure and get the height of the lights. I then go to the wall and do the same thing, right? I just do not know how to adjust the lights! I can do the fog lights, just not my headlights.
I had it done quite a while ago at a Ford place 3 towns over. They drove my car like 72 miles or something. They messed with all my radio preset stuff, too. I will never go them again. Not even if my car breaks down in front of their dealership. There are just some things I do not like! Thanks!!
ripper
If you open your hood and look over each headlight you will see a cover. Pop that cover open. You will see the adjusters on the outside and top of each headlight.
eliyarbrough
eliyarbrough
Nocona, TX
Thanks! It the cover more like a flap? Is there a certain way to turn it to make it go up or down? Or will I just play around with it some?
ripper
Yea 1st its a flap with a push pin. I did mine once cant remember exactly how it goes but its easy. BE CAREFUL not to break the adjusters. There plastic pos. I put mine out on a dark street and adjusted them.
916_5.0
That garage door trick sounds like it would work pretty well i may have to try that.
