Line lock not working.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Man… that puts a twist on things… I don’t think my lines run like this but I’ll double check. Something tells me the car they used was a non abs car. Either way, thank you this may just be the tool I needed.
I never did ask, but where exactly do you have the line lock installed? Can you show us a picture?
Wells.Strength
Wells.Strength
Michigan
I can get a picture tomorrow, sorry had a volleyball game to be at tonight. So I have mine between the master cylinder and the prop valve on the front line. But I did not set it up like the link shows theirs being done. Mine is just line in and line out. My lines go from master cylinder to prop valve to abs unit (now removed) then to right and left front wheels and then one line to the back.
Wells.Strength
Wells.Strength
Michigan
what did you do differently?
I put mine on the front line off the master cylinder between the master cylinder and prop valve. But my set up is different than that in the link. My lines go from master cylinder to prop valve to ABS unit (now removed) to front right and left wheels and one line to the back. Mine is just one line in and one line out. Not set up like theirs with line taken from master cylinder to front brake then cut and ran from solenoid to left front and line to right front, then line in from prop valve, I think that is how they had theirs anyways..
Wells.Strength
Wells.Strength
Michigan
I think I may have the lines flip flopped front for back… which will make me feel like a dip shit but if it fixes it I’m good with it lol. Just from what I read it seems back port is for the front and front port is for the back, no luck on a schematic yet but I’m going to keep looking.
Wells.Strength
Wells.Strength
Michigan
We got it! I can’t thank you guys enough! Lesson learned for me! If I could buy you guys a round of beers I would!
Wells.Strength
Wells.Strength
Michigan
i dont use them any more
just go to bigger brakes
Went bigger, maybe not big enough. I went to the cobra style dual cylinder Power Stop brand. They work great, but they only hold the car for so long, the cam isn't helping the vacuum at all either. My solution will be a trans brake.
RAU03MACH
NEW MEXICO
that racing for ya
you modify one thing then something else fails then you modify that and so on
you really got to read some forums how people are coping it each mod
some one in here was using torus or fusion breaks i believe that's what i seen
i been so busy i have not hardly been on the site
