Looking for Cam Advice
mustangspartan
MN
If your doing a cam. I have to say my tfs1 with my 1.72 are a blast. If your getting a fox lake shortblock might as well send those heads there and get them ported and ask them what they would recommend for a cam. I know they do porting of intakes also so might want to see all they offer and make the next step wise. It could be only 500-1k more but 50 hp more will make that :) that much more bigger and you wont even think about it much then.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
True... I just got a lot of cash wrapped up in this car already lol...
And this is the set up ill be using,
Trick flow upper and lower
Gt40 x306 heads
Tfs stage 1 cam
1.6 rr
C&l Cai with 76 mm maf cal. 24
24 lb injectors
75 mm tb
Ceramic headers
And that may be it lol can member
Sent from my EVO 3D using tapatalk
lilj4u2njoy
lilj4u2njoy
Forest City, NC
Everything listed I already have just sitting in the garage, now I'm just waiting to do the short block
XxslowpokexX
Queens NY
I dont have alot of experience with SN95's but I do with SBF in general. I have never made good power with the TF stage 1 or 2 cams. Id personally stay away allthough it seems some here are happy with it. Also the stock 94/95 cams are garbage. I'd definitely not stay with stock if doing heads. And a custom grind from a reputable cam guy is best however....If you are on a budget that will cost you a bit extra. But a custom grind for your want sand needs is a best bet..if not...
The anderson N/A cams are pretty sweet. The N41 is a nice piece. As for the 306...Unless you need a shortblock or plan on upping compression you really arent going to get much out of that. I can see you getting around 300rwhp with the gt40x a decent cam and everything else the doctor ordered to make it work. Good luck!
Also..No the gt40x arent super high flowing heads...But they will do you well for a nice street car.
