looking for help
Blown 94 Grunt
I currently have a 94 gt I have a vortech v-3 supercharger. Edelbrock performer 5.0 upper and lower intake, stainless shorty headers bbk shorty x pipe no cats and produmps. I have 30lb injectors and a 90 mm maf i also have a streetfire coil msd box with boost retard and autolite plugs. A zoom clutch custom driveshaft and 3.73 gears. And a hurst short throw. I am planning on changing my factory cast heads for a set of aftermarket aluminum heads and 1.6 stud mount roller rockers and an E cam. any suggestions on which heads to go with would be appreciated. And any other upgrade advice would be great. Thanks
ivan12
Since you already have a performer intake I'd say stick with eddy heads, if you didn't have the intake already I'd say AFRs or Trickflow
B
Blown 94 Grunt
i am also only making 6 psi and i have switched to a 2.95 pulley any idea why only 6 psi my belt isnt slipping and i am at a total loss as to how that is even possible any ideas???????
castine917
wyoming, mi
Blown 94 Grunt said:
what kind of custom cam and where can i get that?
by custom i mean works well with your setup even though it may come out of a catalog. can go through comp cams techs, edelbrock techs, ed curtis, ....... e cams are not bad just not always the best for someone's setup. cost of "custom" versus e cam is small unless you buy a used e cam. i might be willing to buy block or heads used but, not a cam or lifters.
auto_x5.0
estreet heads suck ass, I've read multiple posts of boosted applications where the heads have failed. I would say AFR, but that's only because I've seen alot of cars make good power boosted and n/a. With the e-street you get what you pay for.
Although I did hear that the bare head is still good, its the valvetrain that is bad. So I guess if you can buy a bare set of estreet heads and build the valvetrain from scratch it may be worth it.
castine917
wyoming, mi
why would someone boost the e street? they are lowest offering from edelbrock with the least chance of being set up for high horse that you want from a supercharger.
Venomous96Cobra
Central Florida
e street heads are a good entry level upgrade if you want a bit better flow along with a Cobra upper and lower and 24lb injectors, and calibrated maf they will make a street ca more enjoyable! but these are not good heads in a boosted application...
