Loud fuel pump
Phoenix0783
I assume that's what it is since it's an electrical motor noise. Happens when I'm stopped at a light. It comes and usually shuts off about about 10 seconds. If I just barely touch the throttle, that will stop it too. Do you think I'm correct in my assumption?
RichV
CO
Fuel pump is usually a loud hum coming from the trunk area. When the FP gets loud it does not change tone in my experience.
P
Phoenix0783
Loud hum would describe it. Does that mean it's getting ready to go out?
RichV
CO
You know most will say yes, including myself. I did have a buddy with a loud one that lasted over a year, he eventually replaced it anyway.
P
Phoenix0783
Well it gave up the ghost today. No priming or anything. Checked fuse and inertia switch. Parts store was able to get one in. Replacing tonight
P
Phoenix0783
The new pump still gets loud sitting at intersections sometimes. Any thoughts?
how loud are we talking about I mean louder then when it primes prior to starting it? Get a louder exhaust BAM problem solved :)
P
Phoenix0783
Louder than when it primes, yes. It's pretty audible over the exhaust.
It's got Flowmasters on it so it's not exactly quiet.
I can't really remember ever hearing my fuel pump even when it was stock other then when I primed but I am not a motor expert by any means.
P
Phoenix0783
It should be running the entire time the engine is, right? No cycling? 97 Cobra since I don't think I mentioned.
kenny150r
Nevada
Is your AC working? The A/C cycles on and off if it is low on r134a and the compressor clutch can make some noise if burned out!
Twista
Mine was super loud because i didnt have a back seat or anything back there. Soon as i put a back seat in.. its pretty quiet now.
I replaced my pump with a walbro 255lph i think and it was loud as the bad one right after the install. That all changed when the seat cushion was installed.
senior001
