Loud fuel pump
Phoenix0783
I assume that's what it is since it's an electrical motor noise. Happens when I'm stopped at a light. It comes and usually shuts off about about 10 seconds. If I just barely touch the throttle, that will stop it too. Do you think I'm correct in my assumption?
Fuel pump is usually a loud hum coming from the trunk area. When the FP gets loud it does not change tone in my experience.
You know most will say yes, including myself. I did have a buddy with a loud one that lasted over a year, he eventually replaced it anyway.
P
Phoenix0783
Well it gave up the ghost today. No priming or anything. Checked fuse and inertia switch. Parts store was able to get one in. Replacing tonight
how loud are we talking about I mean louder then when it primes prior to starting it? Get a louder exhaust BAM problem solved :)
P
Phoenix0783
Louder than when it primes, yes. It's pretty audible over the exhaust.
It's got Flowmasters on it so it's not exactly quiet.
I can't really remember ever hearing my fuel pump even when it was stock other then when I primed but I am not a motor expert by any means.
P
Phoenix0783
It should be running the entire time the engine is, right? No cycling? 97 Cobra since I don't think I mentioned.
kenny150r
Nevada
Is your AC working? The A/C cycles on and off if it is low on r134a and the compressor clutch can make some noise if burned out!
Twista
Mine was super loud because i didnt have a back seat or anything back there. Soon as i put a back seat in.. its pretty quiet now.
I replaced my pump with a walbro 255lph i think and it was loud as the bad one right after the install. That all changed when the seat cushion was installed.
