MAF Voltage- Consistent between Brands?
oilspill
Atlanta, Ga
Does anyone know if MAF signal voltage is consistent from one brand MAF to the next? or could it vary?
I ask because my meth injection is set to inject based on a certain voltage and now that i have the car back with a different MAF the meth seems to be spraying WAY later than it was before the change. So much so i was convinced it wasn't working.
Obviously i can adjust the set point down and test but was curious if anyone had thoughts or knowledge.
apsmith49921
Im not sure about brand cross over. But if you change the maf scaling can be different. 5v on a ford 80mm maf is different than 5v on a 90mm maf
What did you have, what did you swap to? Saying you swapped MAF's and leaving the rest open for us to guess I don't think will lead to good info.
Michael Plummer
Brockton, MA
Your transfer function depends on how it was flowed at Pro-M (ducting & air filter before the MAF). The Lightning MAF is Ford, and Pro-M Racing does the SCT MAF (private label). Once installed in your vehicle, this transfer function can change if your tuner adjusts the MAF's transfer function based on its tuning. You should only use MAF voltage for turbo, and positive displacement supercharged applications or PSI for centrifugal superchargers.
I hope this helps
Michael Plummer
oilspill
oilspill
Atlanta, Ga
Helps, appreciate it. I do have a PD blower so will likely adjust voltage setting and see how she likes it.
95GTS5L
Suffield AB
Vortech project done. Road test is next, when ever dry roads arrive, hopefully soon.
EdgarR213
