Want To Buy main ground wire
jwhisl
Oklahoma
I need the ground wire that goes to the battery and plugs into the harness by the fuse box if anyone has one. Thanks
You would be better off making your own. Go to your local car audio shop and tell them you need a piece of 4 awg and some ring terminals and you can make it what ever length you want.
J
jwhisl
Oklahoma
Isn't there a small ground that goes to the fuse box also? I think it was a gray round plug
If you are going through the trouble of upgrading power/ground wire I would really recommend replacing them all as its not a bid deal and can help to reduce problems later.
There are 3 grounds - battery to chassis - Battery to engine - Chassis to block
Win
Kennesaw, Ga
this or using some welding cable
then of course heat shrink on both
