maybe running rich....
seth_96_gt
wats up everyone i recently swapped out my 30lb injectors for a set of 60s (mods include a procharger p600b running 11 psi trickflow heads cobra intake punched out to a 306) when i brought it to the tuner with the 30s it was running 13to1 lean so i thought goin to the 60s whould be suffice iv also got 2 maf a c&l for the 60's along with a proflow the tune i have is for the c and l but i didnt have the right sized rubber addapters to fit it so i just put in the proflow i dont know if that matters but anyways the car at full throttle sputters and dogs while if i ese into it it goes a bit better im just seeing wat you guys can think of any other ideas would be great cause im at a bit of a loss
sbr420a
i think 60's might be a bit of an overkill. but someone elsse needs to chime in
seth_96_gt
thats my next step actually im new to the boosted world also it wont spin past 5500 rpm like once it gets that high it just falls right on her face and backfires i was also thinking that i could be floating valves(knock on wood im not)
Paul
42s would be fine, but since you've already got the 60s, they'll work.
tommybunz
42#'s and you gotta use the right maf i would go w/ the proflow. the c&l reaks havoc and inconsistant
