MGW shift handle Q
Slykin
Tyler, Texas
I can't imagine why a better shifter would make your transmission whine. The only thing I can think of, is that if the little plastic cup the shifter goes into isn't there, then it might grind. I doubt that happened though.
robb15033
Northern Va.
I read that I shouldn't have shift stops set up for my transmission because it has internal shift stops and can easily damage the transmission so just leave them out. I took my bezel off yesterday and checked the shifter and both nuts that adjusts the shift stops were missing. I'm guessing the previous owner did this right? But I'm still experiencing 2nd gear grind only sometimes. Which is very annoying. So the only adjustable part of mgw orange shifter are the shift stops that can contribute to this?
This is how mine is set up. NO stops installed. Instructions mention this as an option because of above mentioned internal pertection. Grinding would be a clutch cable adjustment, throwout bearing, ect
g36 monkey
Orlando, Fl
No, he was definitely going waaay too far into gear in second and 4th, and not going far enough into gear in 3rd. Shift stops are very important on the t5/t45 cars. Which is what you have robb, unless you switched to a TR3650 which has internal stops.
robb15033
Northern Va.
  1. I read from Tremec that they do, I will check into it some more......
    www.[B]tremec[/B].com/oem/support/.../TKO_Installation_Tips_117_117.p...
    You +1'd this publicly. Undo
    File Format: PDF/Adobe Acrobat - Quick View
    Installation Tips. Thank you for your recent purchase of a TREMEC TKO transmission. ... All TREMEC transmissions have internal stops and can not be over shifted. When installing ... must use a Ford T-5 speedometer cable end. (Note: If you ...
g36 monkey
Orlando, Fl
You should have a borg warner t5. Tremec bought borg warner, but I was always told the t5 did not have shift stops. Either way, his car was definitely getting slammed too far into gear and would grind like hell, now that I adjusted the stops its perfect :)
robb15033
Northern Va.
OK, I got ya- I left mine off, didn't install them. I saw that option mentioned in the MGW T5 directions and e-mailed them. Thats how I got my opinion on it. Thanks again, always helpful. Appreciate it.
On a side note, without starting a new thread, What fluid are you using in your T5 gear box? Thats something else i contacted TREMEC/ Borg warner about- I've used Mobil1 automatic trans fluid for 15 years. They said at the time something called "Syncromesh" could be used too. My Mobil1 has been just fine with my 300K miles on the tranny. ust curious....
g36 monkey
Orlando, Fl
If I remember the capacity is like 2.3 quarts in the T5, and the guy I had rebuild mine said don't fall for the synthetic gimmick, etc. He told me to just use 2 quarts of Pennsoil dex/merc (I forgot which number specifically, any part store can tell you) and then top the rest off with some Lucas gear oil. Seems to be fine to me.
robb15033
Northern Va.
Manual transmission holds 5.6 pts. You can use what you want. I would bet my left nut it wasn't a Mustang shop who recommended Pennzoil & Lucus in the gearbox. Tremec/Borg Warner states that they recommend two fluids- Mobil1 automatic transmission fluid or GM Syncromesh.
To each, their own though- what ever floats your boat- different strokes for different folks-
Tally_4.6
Tally_4.6
More well known than you
Clermont, Fl
Got some grinding Jeremy. :(
Last night casual driving, and this afternoon rippin' it.
2nd gear
det_riot
Dearborn
so how are you judging when the car is "too far" or "not enough" in gear? i'm definitely picking up one of these this summah and i like being informed =]
g36 monkey
Orlando, Fl
It's in the instructions, but you adjust the shift stops to just barely be touching the shifter when it's fully in gear.
