Justang
:icon_salut:
Justang said:In all honesty I don't think I've ever activated my cruise control so I don't know the answer to your question. I think fix the odometer problem first and see what happens after that.
CC'S95GT said:If the cruise doesn't work either then the problem is the plastic gear on the end of the VSS.
The Vehicle Speed Sensor is on the driver side of the trans. It has 1 bolt holding it in (10mm socket I think).
Once you pull it out of the trans, pop the C clip that holds the gear on the end of the VSS and the gear will pull off of the end.
The stealership should have a replacement, or you can order 1 from the catalog.
Since you have 3:73 gears you'll need the white 23 tooth.
Also ck the o-ring on the base of the VSS for pliability and cracking. You don't want to go back under there again for a leak.
Another easy fix. you can do this.
good luck man
CC'S95GT said:You don't need the whole sensor! Just the plastic gear on the end.
You can order the 23 tooth if you want or ck at your local ford dealership.
You might get a little dribble of tranny fluid out when you pull the sensor out. Not much at all. You might need a drip pan.
It probably wouldn't be a bad idea to roll under there before you buy the gear just so you familiar..
If you want me to talk you through it, send me a pm and I'll give you my #.
OnyxCobra said:my 23 tooth is a white gear...
CC'S95GT said:I got mine from the ford dealer, but the guy did say it is not normally a ford part. I believe he said it was a dodge gear.
