Mileage odometer+trip odometer stopped moving
T
Twista
Justang :icon_salut:
Thanks again guys. Sorry, i suck at car stuff, but rock @ computer stuff :dontknow:
T
Twista
Wait.. timeout. Does this speed sensor thingie have anything to do with my cruise control. I just realized my cruise control suddenly doesn't work anymore either.
Could this be another problem? For the last two days i been trying to turn on my cruise and it hasnt worked.
No cruise control+ No working trip/mileage odometer
Justang
In all honesty I don't think I've ever activated my cruise control so I don't know the answer to your question. I think fix the odometer problem first and see what happens after that.
CC'S95GT
Hampton ,Ga.
If the cruise doesn't work either then the problem is the plastic gear on the end of the VSS.
The Vehicle Speed Sensor is on the driver side of the trans. It has 1 bolt holding it in (10mm socket I think).
Once you pull it out of the trans, pop the C clip that holds the gear on the end of the VSS and the gear will pull off of the end.
The stealership should have a replacement, or you can order 1 from the catalog.
Since you have 3:73 gears you'll need the white 23 tooth.
Also ck the o-ring on the base of the VSS for pliability and cracking. You don't want to go back under there again for a leak.
Another easy fix. you can do this.
good luck man
T
Twista
good luck man
So can this one sensor cause the odometers to stop working?
CC'S95GT
Hampton ,Ga.
The speedo and odometer are electrically driven from the computer.
the VSS converts the rotating trans to an electrical signal the computer can use.
Your sensor is probably good just the replaceable gear on the end of is stripped. It's plastic, go figure.
T
Twista
im going to change the speed sensor first $20 .. pretty cheap.
Also someone said something about a white 23 tooth one ? Can i get the replacement speed sensor itself with 23 tooths from a parts store?? I was going to advanced auto
Or will i need to order a 23 tooth one online? It seems auto store only stocks 21's right?
Now when i pull this thing out will anything leak out???????????? :dontknow:
CC'S95GT
Hampton ,Ga.
You don't need the whole sensor! Just the plastic gear on the end.
You can order the 23 tooth if you want or ck at your local ford dealership.
You might get a little dribble of tranny fluid out when you pull the sensor out. Not much at all. You might need a drip pan.
It probably wouldn't be a bad idea to roll under there before you buy the gear just so you familiar..
If you want me to talk you through it, send me a pm and I'll give you my #.
T
Twista
I think i might be fine. What im not sure of is: If i go to a ford dealership parts place how do i ask for this piece? Will they try to give me a stock 3.27 plastic gear or do i just say i need a 23 tooth speed sensor gear?
T
Twista
OnyxCobra said:
my 23 tooth is a white gear...
Did you get it directly from a ford dealer? From what i found online the white gears online aren't made by ford.
This is confusing..
CC'S95GT
Hampton ,Ga.
I got mine from the ford dealer, but the guy did say it is not normally a ford part. I believe he said it was a dodge gear.
T
Twista
Was yours white? This one is light blue. Not sure if its worth the 30 minute drive now...
He said its 23 tooth.. so im wondering if it'll still work
