Miss fire
Staff member
Lawrenceburg Kentucky
Most likely a pats issue. Theft light flashing while attempting a start is a clear sign. The theft issue disables injectors from pulsing. All the normal start up crap does what its supposed to, but the comp doesnt pulse the injectors. Either your keys chip is toast, the ignition start switch transponder is bad, but either way.... Any sct tuner can turn off the pats issues. Then you can start the car
Randall Garner
Randall Garner
US NAVY
So I need to buy another tuner, oh joy. To bad I'm still using the on for my newer mustang, any purchase place recommendations
what tuner do you have? It might have the option to do so already and it was just something you stayed out of.
Randall Garner
Randall Garner
US NAVY
X4. But thought these tunes were vehicle specific once linked to the car. Or do I do a restore to stock on my 14 with the x4 tuner. Then go in and scan the 98
Staff member
I do believe only the sct dealer/tuner can alter the pats on/off. Give your sct tuner guy a call. In other words, a simple purchased sct hand held tuner doesnt offer the option to toggle security on or off. Only the sct dealer/tuner guy can.
And this may be simple enough that your keys chip took a crap or the ingintion switch transponder to a crap......but thinking about that.....if you swapped in new parts, they most likely would need to be programed to the ecu.
Yeah....give your sct tuner a call
If you need an sct tuner guy, Blankenship tuning in Shelbyville ky is a phenomenal guy.
Randall Garner
Randall Garner
US NAVY
Thanks. I'll look closer to me first. On the far west left coast there are a couple of shops that do such work
it might be the ground wires by the battery just in front driver side
ill say it again one of those wires will stop the car from starting black thin wires on apron clip check that first
Staff online
