When I back up my car in the morning it makes a moaning sound (best way to describe it). It's pretty obvious it's coming from the brakes, sounds like maybe it's from the back. Is this normal? The brakes don't make any noise when moving or stopping. Could it be the e-brake pads? Any way to stop it?
The brake pads are the ebrake pads, there is no separate pad or inner drum. I get this noise occasionally as well, mine appears to be a sticking issue with the slide pins. But I'd get more input from others. Sent from my XT1254 using Tapatalk
Ok,good to know. I put new pads and rotors on the front when I got the car (Cobra brakes) but I haven't touched the back because they seem fine. It probably would not hurt to pull the rear calipers off and clean things up, the car sat for a while before I bought it.
