beebs90
I agree that I will not need the 30lbs at this time but who knows what I'l do down the line. Price was very good on them so I thought why not, Its not going to hurt as long as I get it mapped correctly. At least that's my hope
That 265 is at the crank, its not easy to make 300rwhp even on a full bolt on na 2v. Again the bullitt intake isnt doing him any favors really. I wouldnt spend the money on injectors until a particular setup is in mind. He could want to do something later on down the road and needs to get bigger injectors.
I partially take back what I said because youre right they would be close to or at 100% duty cycle. That being said there is no reason to go to 30# injectors. When I say full bolt on I mean bolt ons and heads/cams though I should have clarified. Still its not like heads and cams will add so much horsepower to an na 2v that itll need big injectors.
With scott aside because I dont know his combo, Iwarrior is still ok running 24's so thats really not an excuse. Even if he is running close to max he's not over it is my point.
Thats all fine and dandy, my suggestion was if you had stockers. 30s arent good for a lot of hp over factory, which is another reason I said to skip them but since you have them use them and you'll be perfect. Are you going to dyno tune your car?
