AaRoN
King Post Whore
Built is more satisfying than Bought ;D
coats04 said:i bought a 97 gt a couple of months ago too.mine is forsale due to being a gutless wonder.
i did the following
pi intake/cams
o/r x-pipe
subframes
3:73 gears
pro 5.0 shifter
dd bullitts with 315/35 nitto dr's
on a cold night 2 weeks ago at the track i tried every way to get that car out of the whole and never got better than a 2.0 60'
i was cutting good lights but the car was just slow as hell.trap speeds where 93-95 all night long.best 1/4 time was 14.75 @ 94
you will have to put some serious money in your car to make it "fast".there was a twin 62mm '04 gt out there that was only going 12.2 @124 mph. i know LS1 6SPD CAMARO WITH EXHAUST AND 4:10'S WILL GO RIGHT INTO THE 12'S.SEEN IT MORE THAN ONCE.
should have bought a 4v you mean...lol I agree built is nice, but starting with a better engine is always better.Passenger said:Shoulda got a 5.0! :hammer:
Really?..I've heard it was a 13.5-13.8 AT BESTa PI swap is just stock.. and is low 13s with gears and tires
i did the following
pi intake/cams
o/r x-pipe
subframes
3:73 gears
pro 5.0 shifter
low9sGT hahajk said:Really?..I've heard it was a 13.5-13.8 AT BESTa PI swap is just stock.. and is low 13s with gears and tires
niether do 4Vs...but 5.0s have low end grunt and 4Vs have high end power.OnyxCobra said:5.0s are cheaper to buy than 4v's generally speaking. Both can be made fast with not too much money. One nice thing is 5.0s don't "need" a 4.10+ gear to run well.
For the record, a 4v doesnt need those gears to run well, it just makes them amazing. I out ran my buddies modded fox when i was just intake and exhaust, with stock gears... you would really need to ride in one to understand. I had the same general perspective of a 4v as you until I bought one.OnyxCobra said:5.0s are cheaper to buy than 4v's generally speaking. Both can be made fast with not too much money. One nice thing is 5.0s don't "need" a 4.10+ gear to run well.
V said:low9sGT hahajk said:Really?..I've heard it was a 13.5-13.8 AT BESTa PI swap is just stock.. and is low 13s with gears and tires
you cant go by a PI motor, have to go by a PI swap car.. since compression is different and in a sn95 it's lighter. It's not difficult to get a coupe PI gt into the low 13s.. i'm swapping in a PI motor and 5 speed and am looking for atleast low 13s with my mods. I'm dropping my ET streets on it to help the equation.. so we shall see. Seems like me and justin have good luck with auto gt's.. both running relatively good times for the car's mods.. i'm close minus the intake and headers and just a different tuner. Oh well good luck, i believe in my car and that it is capable of better times then what it does now.. it's stronger then the average bear
justinschmidt1 said:V said:low9sGT hahajk said:Really?..I've heard it was a 13.5-13.8 AT BESTa PI swap is just stock.. and is low 13s with gears and tires
Yea..I hope that with pi swap I can get low 13s.
SilverSol said:justinschmidt1 said:V said:low9sGT hahajk said:Really?..I've heard it was a 13.5-13.8 AT BESTa PI swap is just stock.. and is low 13s with gears and tires
get rid of those 3.73's and get 4.10's
