Motor mounts
franklinstein
I have a 95 gt SN95 with some new vibrations due to a bad motor mount. Does anybody know the best procedure for changing motor mounts? Will pulling out the entire motor be necessary to replace the motor mounts?
ivan12
It's not that complicated, you don't need to pull the motor. Lift the car on jackstands, unbolt the mounts and lift the engine with a jack and a 4X4 on the oil pan. Or you could probably use a cherry picker to lift it enough to swap them out
det_riot
Dearborn
Lifting the engine by the jack on the oil pan is a risk to bend the pan no-matter what is used on the jack (4x4, etc). Save yourself the risk and piece of mind and borrow an engine jack from a buddy or use the rafters of your garage.
