Motor mounts
T1264rk
I have a 95 mustang gt, with 302, the motor mounts don't seem to fit right, there's only one bolt holding them to the frame, anyone have this situation? Not sure if there are specific mounts for this year. One of them isn't even sitting flush with the frame?
to me it looks like its not sitting flush on the frame settle
there might be a rivet you need to grind down on the bottom of mount
T
T1264rk
I can get them to sit flush, but I only have one bolt on each mount holding them down
There should be only 1 bottom stud
And 4 that go on the block
If you look at the motor mount bottom where stud is
You will probably see a rivet grind it down
You will need to take the motor mount off
