Mustang AC/Heat Not Working
5-oh-MUSTANG
Canada, Ontario
I have a 95 mustang gt. Neither the Heat or AC are working. Whatever pressure i put it on, nothing blows out of it. I hear something blow out of it for like a sec and it goes away. Can it be the fuse? If so which one is it and wheres it located? Thanks
Are you sure it's just NOT blowing out of the vents and IS blowing out of the defroster?
Or does the fan not work at all?
ProKiller
PA
most common failure, which CC is eluding to, is the vacuum line running from the tree in engine compartment to the pass side firewall. this gets old and breaks. this will force the air only out of the defroster no matter what setting you tell it on the dash. that should be your first thing to check.
RichV
CO
If you're not hearing a fan, probably have a bad one. But you can check it with a meter. My dodge's fan quit working, only the highest setting would blow air. The problem was the speed resistor.
I bet you just need a new blower motor.
