MUSTANG SN95 TURBO
robskw
Sao Paulo
Hii guys, After 3 years The car was parked in my garage I Finally Start my Turbo Project!!
It all started when I bought a Fox Twin Turbo Kit from Ebay!! My Plan was to Twin Turbo the car, after many headaches ( like all ebays craps ) i Sold the Turbo Manifold and Bought a Single Turbo Exhaust manifold from ebay Custom Made everything including the Pipes alot of headaches but funny&cheap project rebuild the Engine with all stock.
I Have alot of plans for the future, Like to Upgrade New Intake Manifold, Edelbrock E Street Heads & Cam setup and take all that junk out.
Lets see the car running the next week.
Here is The List of Mods Up:
Turbo CXRacing Stage III Ceramic Ball Bearing GT3582R
SR performance 75mm Throtle Body
42lb Fuel Injectors
Walbro 255 Fuel Pump
Moroso Main Cap Girdle
Mishimoto Thermostate.
MSD Distributor
MSD coil.
MSD Ignition
RAM Billet Aluminum Flywheel - 6 Bolt 50 oz
King Cobra Stage 2 Clutch.
Alloy Usa 28 spline Rear Axle.
BBK Performance Underdrive Pulley Kit
McLeod Hidraulic Clutch Conversion Kit
Dorman Engine Harmonic Balancer
Ford Racing spark plug cables.
Ford Racing Head Gasket.
Ford Racing Oil Pump
Hurst 3915033 Manual Shifter Billet Plus
Eibach Pro damper Shocks & Springs
PROTHANE Engine & Transmission Mount.
Standalone ECU InjePro ( its Just a new standalone ECU That have alot of assitence where i live).
1-Where it all began
2- Ok Lets Buy Car Junks in ebay
3-Engine Rebuild
4-Turbo and Pipes mounted and the new pulleys scheme Took out the AC.
Continue in the Next Post ...
I will Keep ya guys updated about the Project Soon i Post a Vid with the Car Running :) :headbang:
robskw
robskw
Sao Paulo
Before & After!
EVILSN
Can't wait to hear it run!!!
Sent from my iPhone using My dick
robskw
robskw
Sao Paulo
This looks like alot of fun! How will you tune the car?
I Will tune it with a New Standalone ECU Called Fueltech, its work very well and have a lot of assistance here where I Live.
The one I am using is called FT400 Engine management ECU . http://www.fueltech.net/ft400-efi-prod-3.html
alot of Daily Mustangs also other cars have been tuned by them and works perfectly!
I post Vids soon!
96blak54
Staff member
Lawrenceburg Kentucky
Really cool. I guess fueltech to South America is the SCT to North America... We really dont know what is available in other countries. Thanks for sharing your build.
looking at the intercooler and how it is mounted are you concerned that covering so much of the bottom of the radiator that it might cause overheating problems? I have always been told that they are bottom feeders when it cooling?
Looks like hell of a good time though IMO.
robskw
robskw
Sao Paulo
Not Exactly ttocs, This Intercooler is designed to work this way , it has an air intake which is exactly in the bumper air intake .. If it overheat I Will Try put it vertically that looks alot beautifull and agressive too, but This is the right way to put them. Lets see.
Ya I Spend alot of time with customs parts, its not a Plug n Play setup.
Witzy0070
Montana
I am 90% sure that you are going to need another fuel pump. A second inline one could be very easy to install and keep those AFRs stable. I run an inline pump, otherwise, keep us posted! Looks good.
robskw
robskw
Sao Paulo
ya I Will Use a Bosch or Aem External Pump to have enough fuel Flow. I Come soon with pics of the upgrades .
My Worry Now is Just about the Tranny, Somes say T5 Can easy handle 600hp others say 400Hp u can broken them..
I am Looking for a 350whp Car to start it.
evilcw311
Most Evil Member!
Louisville, KY
You will split a t5 in half before you ever make 600!! People have had issues at 4-450
robskw
robskw
Sao Paulo
What would be a good tranny swap? or just rebuild the T5 with stong internals? Want to make safe 450hp or even more with a trans swap.. Ofc i am starting at something around 350hp.
Heard the 302 5.0 Handle max 600hp Untill the block break, I Use a Moroso Main Cap Girdle to make it safer. But honestly its a Junk project so i am Happy to see any results, lets see.
