My ac heater not blowing!
eliyarbrough
Nocona, TX
I think this is brought up about every other week. It's the vacuum lines. Try doing a search for it. Right below this there's Related Topics. Try looking there.
comes out of the windshield only right? There is a vacuum line that comes out of teh passenger firewall, and then goes across the back of teh motor and always breaks back there. Get a connector and just put it back together.
det_riot
Dearborn
Is it posssible to get a picture of this line and where it's supposed to go! Thanks!
There is only one vacuum line that comes out of the passenger side, it is not hard to see as it comes out with the heater and ac pipes. There should only be one that it came apart from as well...
det_riot
Dearborn
Does it go into a T, and one end goes to the intake manifold and the other goes to the driver's side right by the hinge?
switch96
It's a hard vacuum line. There are two large coolant hoses that go into the firewall on the passenger side through a square rubber grommet. Between these two large hoses is the vacuum line. It does go into a T, one end goes into the plentum, the other went towards the front of the engine IIRC.
det_riot
Dearborn
hmmmm, Maybe a stupid question but what are the lines in this picture that are by the drrivers side hinge, theres 3 of them right over the strut tower.
Paul
Go and actually look in your engine bay and you'll find it. Also, do a quick search as this has been covered in great detail many, many times.
det_riot
Dearborn
I would look but i'm in ohio and my car is in michigan so it's kinda hard for that to happen
