My car has a miss.
96stallionGT
When i put gas in my car, a few miles down the road it will miss at steady throttle, but when i mash it it quits. Sometimes it will do it again later on but not always. It has a new fuel filter on it but i was thinking injectors or maybe needing a tune up. Im new to the site and not good with comp. so hopefully im doing this right. Does anyone have any ideas???
ThePope
When was the last time you did a full tune up on your car?
96stallionGT
Ive only had the car five months and ive never done one. The guy said before i bought it, that it had a miss but it was just a plug wire. Its been doing this for about a month.
Tbuck07
Uhm..a busted 02 sensor will do that....
Fix your plug wire, replace your o2('s).
You throwing any check engine lights?
96stallionGT
The guy fixed the plug wire a few days before i got it. It run like a top till just here lately. The check engine light stays on but i just thought it was because of not haveing all the O2's. It runs great except for the few seconds it does that.
96stallionGT
I'll try that, thanks. So u dont think maybe a bad injector? I know anything's possible.
uncltrvlnmatt
Pa.
Remember the acronym KISS- Keep It Simple Stupid (Not calling you stupid) You know you have a bad o2 sensor, and it could probably use a tune-up since you know it had/has a bad plug wire. Start there, if you still have a problem after that look a little bit deeper.
I'd do a complete tune up.
Plugs
Wires
Coil Packs
02 sensors
Fuel Filter
Clean MAF
Clean IAC
Clean or Replace Air Filter.
Anything i missed guys?
Willis_98GT
DFW Texas
Plugs
Wires
Coil Packs
02 sensors
Fuel Filter
Clean MAF
Clean IAC
fuel filter/injector o rings
and check for coolant in plug vallys
96stallionGT
Well i figured out i had a o2sen. unplugged(which is the only good one) so i plugged it up and its not done it sents.(knock on wood). Thanks for all the help.
joekd
Ct
I would still take the time to at least look at your plugs, even better just replace them since they are cheap
Jerry santos
