My Car Is Bent! *Updated*
McGarrh
So he is the story, one day I was backing out of my friends driveway and I bottomed the front end of the car out. It was a very big bump. Anyways I did not think it did anything until I got under the car to change the oil and this is what I found. I need as much thought and advice I can get on what to do. I also would like to know how much this affects the integrity of the car. I noticed no change in how the car drives at all. Here are the pictures.
Paul
Re: My Car Is Bent!
You bent the car that bad backing out of a driveway? We're you backing out at 25 mph? Holy crap!
McGarrh
Re: My Car Is Bent!
I actually was backing out fairly slow, thats why I cant believe it did that much damage.
Magic
Some time zone
Re: My Car Is Bent!
Take a hammer (big one) and straighten it out as much as you can...
Looks like you caught something (Curb?) as you were backing out...
Paul
Re: My Car Is Bent!
Best bet is probably to have a body shop take a peek at it. Perhaps we've got somebody on the board who is qualified to give you an opinion.
That could probably be pulled a bit on a frame machine, or of course just cut off and a new one installed.
Does it affect the appearance of the car? Does everything still line up?
McGarrh
Re: My Car Is Bent!
Everthing lines up for the most part except where the bumper connects but you cant tell unless you look under the car. This what going to be my project car so either need to get it fixed I guess or sell it down the road.
Re: My Car Is Bent!
What did you bend exactly? The bottom of my bumper is messed up like that too but other than that i can't really see what you're talking about.
Paul
Re: My Car Is Bent!
Look at the core support:
topless95
Re: My Car Is Bent!
dayummmm, I agree about taking it to a body shop. You may have stressed metal that is not easily seen
Win
Kennesaw, Ga
Re: My Car Is Bent!
Damn you did a good number. I agree i would take it to a body shop and see what they think. I have done similiar things in the past to other cars and you start thinking WTF how in the heck.
Re: My Car Is Bent!
i agree, it does look like the core support hooked on something. i think you should use a BFH and gently persuade it back into place. be sure to put another hammer behind as a back up. anything that could have been bent is fwd of the suspension. has the rad moved any when looking from the top,down. you could take it to the body shop and they'll tell you exactly if it can be fixed or replaced, and then do it yourself
GearJamminCanary
Re: My Car Is Bent!
it looks like you slighty bent a lower rad mount...my car was kinda like that when I bought it cuz it was lowered 2 inches :BangHead: I'd just try beating it back into shape with the hammer first and inspect everything. Make sure the rad's not cracked or anything. If you can straighten it out like that, you should be ok. That's what I did.
ProKiller
PA
Re: My Car Is Bent!
i dont think BFH and gently persuade can be used in the same sentence....
thats one of things that i wouldnt feel comfortable working on. take it to a shop IMO
McGarrh
Re: My Car Is Bent!
First thing I may just call the insurance company and see if they will raise my rates for claiming that. If not then maybe I can get some money out of it.
McGarrh
Apparently all that whole piece is just a radiator support and the total repair is going to be only $500. All they would have to do is pull the radiator and put the new support in. I am going to get a quote from a couple other places though.
Steven
SC
Mines a little bent. My race cars was in a V from people tugging on it towing it around. Had a couple other cars that were all F'd up. I wouldn't worry about it. If everything mounts up decent then it's not a priority. Mines been been on the passenger side corner for over a year, and even longer lol.
Just pound it back man. Use block of wood and lower the car or pound it back with wood against it. That won't do any damage to the car. I used to work at the body shop for a while and i also had 91 that had core support problem.
It will be a quite bit of work to change out the core support. Just pound it back and make it straight as you can and you will be fine.
McGarrh
I will try. If it does not work or get the results I want I am going to have to get it fixed.
