My new toy :)
96blak54
Staff member
Lawrenceburg Kentucky
Pretty good idea! The wheels do look great and dropping it a little will set it all off. Do you know if rear gears have been changed?
punched281
Colorado
If its already got a small cam, I wouldn't got with a b cam. Its pretty mild as well. F-Cam!!
Trick flows are sweet! And maybe look for some aluminum heads??
I know most hate on procomp, but I've been around a few cars with them on and they run stellar!
austinw88
austinw88
South Carolina
does the F-cam require valve spring upgrades? I know im putting 1.6 rockers in it either way.
punched281
Colorado
When I did it, we bought the procomp heads with all the goodies on there. I'm not sure its required but probably a good idea while you're in there.
kb1982
Kentucky
The best bang for the buck would be swapping over a set of gt40 heads and intake. If you scour around the web, there are also quite a few used aftermarket heads like TF and AFR that can be had for a reasonable price. With the gt40 setup, you should install different valve springs. As for the intake, i wouldnt mess with just it by itself. No point in having an intake that will outflow your heads. As for intakes, you can also find alot of them for sale used also. When the guys sell of their smaller TF and AFR heads, they usually upgrade the intake as well. You can usually save around 250 dollars by buying the aftermarket intakes used.
austinw88
austinw88
South Carolina
going to start a build thread here soon, I've got the motor almost out just the bell housing bolts and the motor mounts to loosen and shes out. will take some pics along the way. tax money is on its way and its time to do some work. keep a look out for my build thread.
